[Solucionado] Remplazo de micropocesador
20/7/2012 07:05PM
ESTIMADOS
COLEGAS
Tengo un tv marca Philco 21, tiene mal el micro es M37220-M3-155P,
necesitaria sabir si tiene remplazo y cual es ya que aqui en Bs.As.
no lo puede consiguir
Tambien tego un tv Telefunken que tiene tambien mal el micro es
KS88C8316-16, necesitaria saber si tiene remplazo ya que no se
consigue aqui en Bs As.
MUCHISIMAS GRACIAS A TODOS
MAUROTV
21/7/2012 12:40PM
aqui dice que el primero es chino:
TV CHINA MODEL CHASSIS
3I01 STR-F6553,DDP3310,BU2525
3N10 MN18P7328DP,NN5199,AN5539
3P20 KS88C8316DP,OM8838,TDA8356
3S01 ST63T87,STV2112,TDA8174
3S10 ST92185,STV2248
3S28 ST3688,STV2246,1802,1803
3S30 S3F880,ST2247H,D2499
3S40 ST63T87,STV2216,D2499
3S52 STV2110A,TA8445K,D2499
3SYLT ST92195,STV2238,TDA8174,D2499
3T01_3T20 TMP87CK38N,TB1238AN,TDA8403
3T36 LA4285, TDA9302, 24C16
3Y01_4Y01 LC863324A, LA76810A, C5148, D2499, LA7840, LA4285, JF0501-1215, TDQ-3B9/126CWA
3Y03 LA8633XX,LA76814,LA7840,D2499
3Y11 LA8633XX,LA76810,STR-6653
3Y30 LA76930,LA7840
3Y31 LC8635,LA76818,ST9302
4A02 CTV222S,TA8759BN
4N01 MN152810,AN5195,AN5534
4N10 5198,AN5539,D1555
4P10 MTV880,OM8838,TDA8356
4S02 ST63T87,STV2112,TDA8174
4S02PIP ST63T87, STV8224, STV2116, STV2180, TDA1905, LA7910, TDA8174, STV5111
4S03 ST63T87,STV2112,STV5348
4S30 ST63T87,STV2116,TDA8174,TDA1905
4T01 TMP87C38,TB1238,LA7830,C2499,D5148
4T30 TMPA8809, STRG9656, TDA7496(TDA7496S), LA7841, TA4053, 26C16
4T60 TDA8177, PMS1341, TDA7496S, 24C16, 1207
5D20 TDA9808, MSP3410G, TDA9111, ST92196, KA2500, TEA5114A
5D20 v2 ST6709, TDA2616, TDA6111Q
5D60 MSP3410D, KA2500, AN5891K, TDA9115, LA7846, STRF6656, TA8256(TA8246), 24C16
5D90 M3722M6,STR-S6709,TDA8351
5I30 VCT3803,MSP3463,TA8246,TDA8359
5N10 NN5198K, STR-S6709A , C5148, TA8427K, TA8246A, JF0101-0166, TDQ-3B9/126CWA
5N11 STR6656, MSP3410D, PQ09RD11, NN5198(NN5199), STV5348, CD4052, TA8859, AN5612, 24C04A, TA8427
5P01 CTV322S,TDA8362,TDA8425
5P20_5P21 STR-S6709,Z90255,TDA884,TDA8354
5P60 KA5Q12XRF,TDA93XX/N2,TDA4863,C5150
5S01 ST6388, STV2216, STV9306, STV5112, TDA7439, STV5348, STV8203, STR6709, STV8223, LA7910
5S10 ST6388, STV2286, STV9306, STV5112, TDA7439, STV5348, STV8203, STR6709, STV8223, LA7910
5S15 LC863324A,LA76810,LA7840
5S30 ST63T87, STV2116, TDA8174, STV5111, TDA1905, STV2180, STV8224
5S196 ST92196, STV2246, STV9306, TDA7263A, TDA2030A, TDA7439, STR6709
5T03 TMP87C38, TB1238, TA8200AH, TA1245
5T28 TB1240,TA8427,STRG9656
6D92 LA76930, LM2429, LV1116, LA4278, LM1246, STV6888
6M20 LA7846, UC3842, KA5Q1565RF
6M23 KA5Q1565RF,UC3842,LA7846
6P16 KA5Q1256,M37281,LA7566,KA7631
6P18 TDA12067H, TDA9333, TDA4863AJ, TDA6611Q
6P18D TDA12067H, TDA9333, TDA4863AJ, TDA6611Q, TDA7266, TDA8759, HY57V641620HG, PW1230, STR-W6756
6P30 KA5Q1265RF, DTT7600, AMT2400, TDA2616, STV9379, FLI8125, FLI2350, OM8380H
6T20 TMP88PS38N, TB1251N, LA78335, MSP3410D, TA1216AN, TA8256BN, STR-F6656
6T20A TMP88PS38N, TB1251N, LA78335, MSP3410D, TA1216AN, TA8256BN
6T20AV TA1218N (TA1219N)
8TP5 TDA2616,M3413,PW318
88HD STR9656,MTV230,TDA9885
CH16 STR-F6454R,TDA9384,TDA8350Q
CJ11 TMP87CK38N,TB1238AN,LA7830
CJ13 TMP87CK38N,TB1238AN,TA8427K
CJ14 LC863328A,LA76810A,LA7841
CJ16 LC863328B,LA76818,LA7840
CJ20 8803CPBNG3UH5,LA78041,TA1343
CJ21 TMP8803CSN,AT24C08,LA7840
CN9EA TMP87PC38N,TB1238,TA1275,TDA7067,TA8403
CN18EA CH08T0609,LA78040,D1651,STR-G5653
GU22 TDA8177,NJW1168,TDA7495,FLI8125,FLI2300
JL ST92195,STV2246C/48C,STV9306,C5299,C5296
M03 M37160,M61260/64,LA7840,D1651,D1710
M17 TMPA8809, TDA8944, NJM1136, CD4052, MC44608, TDA8172, TDA9801A, TDA9874APS
M28 TMPA8809, TDA8944, NJM1136, CD4052, MC44608, TDA8172, TDA9801A, TDA9874APS
M35 MC44608,VCT3831,MSP3415,TDA8944,TDA8172
M35B MC44608,VCT3831,TDA8172
M36 MC44608 VCT3831 MSP3415 TDA8944 TDA7057 TDA8172
M36B MC44608 VCT3831 MSP3415 TDA8944 TDA7057 TDA8172
M41 MC44608 VCT3831 MSP3415 TDA8944 TDA7057 TDA8172
M50 TMPA8821,STV9302,C5586,D2499
M60 TDA16846,TDA8177,TDA8945,TDA7266
M62 TDA12066,TDA16846,STV9380
M65 TDA12000,STR-W6735,TDA8177
M68 TDA16846,TDA8177,TDA10046
M113 TMPA8809, TDA8944, NJM1136, CD4052, MC44608, TDA8172, TDA9801A , TDA9874APS
M123A TMPA8803,MC44608,STV9302
M123L TMPA8802
M129A TMP87PS38N M17, TB1238AN, TC4066BP, TDA7496, TA8403, 24C04, TDA16846, KSS1850-XX
M134 TMPA8809,STR-W6735,TDA8177
MA1 OM8370,TDA9302,TDA16846
MT02 M37220M3,LA7838,M52340,C5339
S11 TMPA8803,LA78040,C5287,D2499
S12 TMPA8803,STV9302,C5287,D2499
S13 TMPA8809,TDA4864,C5586,,C5885
S13A TMPA8873,TDA4864,STR-W6553,C5885
S22 TMPA8829,TDA8177,STR-W6856
SS1 LC863320A,LA76810
SS2 LC863528A,LA76810-LA76818
SY31 LA76933,STR-W6553,D1556
TV2K 2SD1710,ST92195,STV2248,TDA8174
TV3K ST92195,STV8203,STV2246
TV4K 2SC5299,ST92195,STV2246
o sea que va a estar en chino....
del segundo:
Ese micro µP lo usa el chasis K15B y el KCT15B.
En el circuito de este TV que está en Manual de TV Color HASA Nº 31 pagina 148 aparece que el µP= kS88C8324, pero en el micro que esta en el chasis del TV trinorma dice: SSM 174PT S88C8316-16.
Otros TV que llevan el mismo chasis K15B o el KCT15B es el Samsung CN5038Z, Telefunken TK2098, TK2099, Serie Dorada SD20X2C, etc.
El TV lleva el TDA8841, TDA8356, TDA6107, KA7630, KA3S0680RF, LA4425, 24C02, KS88C8316-16 = SSM174PT.
Usar otro micro KS88C8316-XX con otra programación no realiza todas las funciones o no reconoce el control remoto o no enciende el TV.
warneri92 38.326K
27/7/2012 05:38PM
ESTIMADO
WARNERI92
Muchisimas gracias por tu atencion estare verificando cual puedo conseguir y
poner
MUCHISIMAS GRACIAS
MAUROTV
